My 1997 P Plate 2.5 V6 Auto
this is her before i put her on the road,
notice the missing jacking point covers
many thamks to FENIX it now has all 4 again
BIGBOY1
Re: My 1997 P Plate 2.5 V6 Auto
whats needing done to get her on the road?
the list is big
but im a maniac (sorry mechanic) lol
1. both front outer c.v. boots
2. both front brake pipes
3. both front brake hoses
4. both front suspension arm rear bushes
5. both rear brake hoses
6. both rear brake pipes
7. centre and rear exhaust parts
8. small bit of welding at handbrake cable mounting
9. fuel pipes
10. few bulbs
9. fuel pipes
10. few bulbs
BIGBOY1
Not too long a list! Should look good when it's finished.
She is on the road now. Only mods are,
1. Rear 60mm lowering springs
2. Set of the vauxhall, Opel GM mudflaps.
3. Exhaust make by Anderson engineering (ME). Lol
BIGBOY1
Good project, looking nice Look forward to seeing it when you have got it finished
maid marianne
I just need to get her clean and scratchless.
The alloys are in a ridiculous state with grease and brake dust.
The interior is imaculate. Especially for 101000 miles.
Was thinking of getting a set is zafira gsi alloys or the 5 spoke zafira ones.
Not going to do a lot. Going to try to keep it original'ish.
BIGBOY1
very good project mate
BIGBOY1 wrote: Exhaust make by Anderson engineering (ME). Lol
tell me more mate
vinny_69
cut off the old one just behind the cat jointgot a length of 2" straight pipe used pipe bender to shape, had a peco 4 back box that i bought off a mate for £10 and welded it on
started running it on the 1st of may, decided a week later that it was too noisy and found a centre section off of a rover 200 that i scrapped and i cut the box out and welded it in to the cally
now sounds the dogs danglys. lol
BIGBOY1
Stock V6 exhaust bore is 2.5". Custom stainless steel designs using the same bore will give improvements. A larger 2.75" bore will give greater improvements but only really effective when a larger bore is applied to the entire system (manifolds through to back box).
it was the only thing i had.
might get another one. not sure yet.
BIGBOY1
Two previous V6's that i have owned have had 2.5" vauxhall standard exhaust system fitted before haveing a powerflow system fitted.
