found a plug!!
Re: found a plug!!
yee it should but it was the only thing i could think of that is that long and comes up the back, i dont know the manifold on the 20L that well but is there a not a sensor down the back ICV or somthing like that is it conected
Re: found a plug!!
looks like the oil level sensor wire.
Re: found a plug!!
Still trying to find out what the hell this plug does... will be having yet another look tonight...
Re: found a plug!!
the wires are 100% brown and brown/green...
The other end does just join up with the wiring loom... so no idea where it should go...
Re: found a plug!!
did you take the wires out that they had between the terminals ???...did any lights come on??
Re: found a plug!!
yep took the wire out... no light came on...
Re: found a plug!!
leelee wrote:looks like the oil level sensor wire.
I think leelee is right, exactly the same connector is for your oil level sensor at the top & front of the sump
Re: found a plug!!
i agree, found it on the wiring diagram in the haynes and the oil level switch has brown, brown/green wires and would make sense that i get no EML light with it unplugged as its not part of that circuit...
so whereabouts does it plug in?
Re: found a plug!!
no not the EML light, but the oil level light should have come on
