key wont turn in ignition barrel
Re: key wont turn in ignition barrel
Yeh this exact thing happened to my old 2.5 Calibra. Never did get it sorted but when trying to turn the key, I had to wiggle it whilst pulling it out very slowly for it to catach correctly. Mine was down to the fact that the key was starting to where a little and wasn't putting the pins in the right position for it to turn. So replace or s said above, wiggle it and have a bit patients.
BAD63R-V6
I had this when I picked mine up, was sat at a petrol station blocking the place because I couldn't get the key to turn no matter what. Turns out the tumblers in the barrel were all jammed up, gave it a good spray with WD40 and it was fine.
MarkSE7
barrell is out and car will start with key by transponder, but with no ignition barrell the steering lock comes on
what i need is another barrell and key, and get a dummy key cut so as to start the car and have my key taped to the transponder and hey -ho it should go
any one got a key and barrel
jat noahn
Have you tried a squirt of wd40 in the keyhole?
Robs-se wrote:Have you tried a squirt of wd40 in the keyhole?
oh yes
jat noahn
Users browsing this forum: Majestic-12 [Bot] and 38 guests
