Calibra BC- Doesn't fully work
Re: Calibra BC- Doesn't fully work
you will get them from your Opel dealer part Number 93154848 but they are expensive ...£5 each they are 5W/12V halagon bulbs, only used in LCD dashs like the Astra GTE, Vectra 2000
just found this link
http://www.auto-essentials.co.uk/ecomm/ ... 1f3dcb606e
Guys, my engine is xev (eco-tec),what is the code on bc for my calibra?
Thanks
Thanks
vule74
you need to tell us what code you have ...hold down both buttons on the BC switch by handbrake and take a note of the readings on BC
Code 42 is Cavalier (or Vectra A over your way ) with Motronic M2.5 and for a LCD dash reading in KPH and with Tyre size 175/60R14, 195/60R14, 205/55/R15
X20XEV in KPH should be 127, 129 as far I can see
