2 electrical problems :(.
Hello guys and girls, I've got 2 problems I need some advice on . First one is my rev counter has stopped working altogether, it used to go up and down like a bad earth but if you tapped the glass on the clocks it would return to normal. It's happened again as I was driving so gave the glass a tap but it hasn't seemed to sort the problem out. Would the clocks be at fault here?
Second problem is my standard alarm, the red light doesn't flash once the cars been locked for a while yet the light flashes when I press the button inside the car. What could this problem be?
I hope you can help .
Rob.
Rob.
