Fitted new motor
Fitted new motor
Fitted new window motor on passenger door today
still not working.I can hear the relay clicking but it
is as if there is no power going to the motor.What a
pain after stripping the other one out and there was
probably nothing wrong with it.Does anyone have any
ideas?
ideas?
Re: Fitted new motor
the best person to answer you Craig is your freind, you could both meet up fix the window and kiss and make up
craigyboy wrote:That sounds like a plan mate
well im sure if you where to ask him he would help, thats the kind of guy he is just no fighting boys
well i like Craig but i also like David, theres only one way to find out
have you checked if the motor is getting power??? could be the contacts in the door connector have you checked that is twisted tight ??
Ive checked that Fraz.theres power going to
it as i can hear the relay clicking when i press
the switch
the switch
Got the motor going in one direction
so its not changing polarity.does anyone
know where the window module is located?
the relay is in the drivers kickplate ...and I think apart from the motor the switch that is all there is
