Speedo and Oil Gauge
Hi Guys,
My oil guage sometimes goes nuts, siting on over 5 bar, even on idle siting on 4 bar. To address this i've cleaned the connectors on the oil pressure sender, which only seems at times to fix the problem. Has anyone else had this problem and found a solution?
Also
The speedo seems to sit on zero and idle and tick between 0-10, on accleration it will initially sit on zero and then suddenly pop up to the right speed. Has anyone else had this problem and found a solution?
Thanks guys for your thoughts.
Also
Re: Speedo and Oil Gauge
BMJ wrote:Hi Guys,
My oil guage sometimes goes nuts, siting on over 5 bar, even on idle siting on 4 bar. To address this i've cleaned the connectors on the oil pressure sender, which only seems at times to fix the problem. Has anyone else had this problem and found a solution?.
change the sender unit
BMJ wrote:The speedo seems to sit on zero and idle and tick between 0-10, on accleration it will initially sit on zero and then suddenly pop up to the right speed. Has anyone else had this problem and found a solution?
could be the speedo cable or the speedo drive bit in the gear box ...cable is a bit harder to change than the gear box sender so would try that first ..its only plastic so might be worn
Thanks Fraz, I'll look into it.
Users browsing this forum: No registered users and 45 guests
