Fuel Reading Issues
Fuel Reading Issues
THE SITUATION:
The 'Range' feature on the Trip Computer reads as 'F'
The 'Fuel Gauge' reading on the dash dials stays on Full, upon start up, and whilst the car is running...
I'm thinking Faulty Sender Unit, or wiring to the Sender Unit...
He suspects that it's an electrical fault...
Anyone experienced such issues before??
Re: Fuel Reading Issues
may be short to earth
Fraz wrote:may be short to earth
So where to check for the Bad Earthing?
check all connections are clean and tight ..what have you had off recently??? the sender unit or maybe the dash or even the fuel computer ...just check everything is fitted correctly
Fraz wrote:check all connections are clean and tight... what have you had off recently???
the sender unit or maybe the dash or even the fuel computer... just check everything is fitted correctly
It's not about my car, so I'll have to ask the Bugger a few more questions!
But I'll check everything that may be possibly related to this issue...
THANKS...
