Track rod ends and wishbones - pairs?
Re: Track rod ends and wishbones - pairs?
if your buying some buy good ones
http://www.ebay.co.uk/itm/Heavy-Duty-Co ... 1c28ca339f
and not
http://www.ebay.co.uk/itm/2pc-COIL-SPRI ... 4d08b8b2a1
the 2nd pair con slip off alot easer than the 1st type
and not
yeah but when you dont have any, their better than none
Thanks guys, and thanks steve for the links, the 1st ones look good, and not that expensive either
How do you know if bearings are right way up? Does the small or big hole go on shock first?
Cav SRI
Cav SRI wrote:How do you know if bearings are right way up? Does the small or big hole go on shock first?
the large aperture goes onto the shock shaft
