My back end is 20mm higher than my front end!
It will come down, how long have they been on? you will need to drive it for abit. Please don't cut springs or they will never seat properly
off the clock/your top 16v speed?
i had similar prob with mine when i fitted rear dial bushies. i contacted regal and ordered 2 rear springs to what i wanted, now car sits great. aprox £90 for then tho, worth it when when your happy with how car sits
ecosseM
RIC this is the natural stance of the car as with a lot of modern cars something to do with drag eficency i think as the new big Citroen lowers its front end when you hit a certain speed on the motorway to save fuel.
I had mine lowered 35mm at COURTENAY with new shocks and springs and it still sits higher at the rear(see pic) even after a few years was thinking about dropping the back a bit more but worried may upset the handeling plus i use the car to go away in the summer and put a lot in the boot so could cause rubbing probs.
[img][img]http://work.aevans.net/uploads/qQbdGp5GblgA.jpg[/img][/img]
I it was not for bad luck i'd have no luck at all
check this out one of the funniest cartoons i have seen
put some -60mm springs on the back, that will sit it down nicely [img]/smile.gif[/img]
Have a look at my gallery pics of my old SE4. -60mm all round
DAN
calibra2zero
