drive shaft/cv boot
Re: drive shaft/cv boot
Have now got a tube of grease, how easy will it be to get the grease in with the boot still in place. Thinking of using a pointy thing like from glue tubes and putting it under the end of the boot and squirting in a bit at a time. Anyone any other ideas?
thanks
vinny_69 wrote:don't forget if you need a hand
You'll certainly hear me shouting, now your an expert, cheers
it's not rocket science Rob i even did the old mans inner and outer on his corsa C
Always willing to give things ago, normally i'm only heard weeping when it goes horribly wrong like i did with my drivers side wishbone
do you want me moby number?
apart from the normal tools Rob
the only other thing you will need is some crimper pliers or a hammer,flat bladed screwdriver and a brick
Only thing that troubles me are the balljoints. I'm useless at them. Need to get the wheel off and see if the boot needs replacing now as well. If you want to pm me your moby that could be helpful at some point if i get really stuck.
you only need to pop the lower one Rob,easy enough big bar and hammer Tazz has taught me well also pm sent
Suspecting the cable tie on the driveshaft end has loosened hence grease coming out. Was jacking it up to give the calipres a clean up anyway.
pop down to halfrauds gypsie lane Rob the kitt cost about 7 squid (bood,grease,ties) but they have to order it in
vinny_69 wrote:so i take it they dont go very often then?
had a little looky around and its either 6 squid for a boot or 60 squid each side (shaft,cv and new abs rings)
£60 driveshaft each? that mechanic thats got my calibra's telling me for mine its £240 for the pair & his 1st quote was £500 each side! one of my mates wer shocked when i said that to him & he asked wer they gold plated at that price! anyway i get my new SE2 thursday!
frankej
vinny_69 wrote:pop down to halfrauds gypsie lane Rob the kitt cost about 7 squid (bood,grease,ties) but they have to order it in
http://www.vauxhall-car-parts.co.uk/aca ... 2853N.html
£5
whippit
Users browsing this forum: Majestic-12 [Bot] and 57 guests
