clunking intermitantly when turning
HI again everyone, seem to be finding more and more things that need sorted on my firts cally,
im getting a clunking noise from the front left of the car when turning left, this does not happen every time i turn
i also get a vibration through the steering at 55+ mph which i put down to wheel ballance ( also getting vibration from rear wheels )
i am going to get the wheels ballanced today and see how things play out, any thoughts on the clunking noise?
scott_j_g
Re: clunking intermitantly when turning
If it was regular clunking, odds on it is CV joint. When turning left it is the o/s, when turning right the n/s.
So that's one off the list
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
GreyDJ wrote:If it was regular clunking, odds on it is CV joint. When turning left it is the o/s, when turning right the n/s.
nice 1 lets continue to reduce the list
scott_j_g
It could also be a broken spring, the best thing to do is to strip the strutt and inspect and renew worn parts
tazz666 wrote:It could also be a broken spring, the best thing to do is to strip the strutt and inspect and renew worn parts
yeh i have cheked the spring its fine, not on the original springs has been lowered by previous owner, i think i will strip id down as a last resort, will try and check all of the above first
scott_j_g
Users browsing this forum: No registered users and 96 guests
