Top mount bearing
Top mount bearing
Is it possible to tighten the nut without taking the leg off?
Re: Top mount bearing
yup just leave the car with the weight on the wheels, take the top strut mount off and the nut it there
Thanks Fraz, thought the nut would be just too far down to reach
You might find once it starts to get tight the strut may spin round,try an impact driver
the strut piston will spin, thats why there is usually a method to lock it right at the top of the piston. It can be a fitting for a spanner or allen key or torx
Nuts tightened, eyes watering , cured most of my knocking now, i can now feel the road as it should be ........... Pot holed
