LCD Dash help wanted LOCAL AREA
Re: LCD Dash help wanted LOCAL AREA
by Fraz » Tue May 11, 2010 8:39 pm
I had one of them in the car before ...I used the Calibra clocks casing and mounted the GTE dash into that ......its did need a bit taken off the actul apature the dash fits into and you also need to drill another hole in teh clear plastic bit for the reset pin
