Calibra Window
Calibra Window
Hey everyone, can somebody help me, i would like to fit a new glass on the driver and passager side without that quarter and make it go all the way down, it there a replacement , maybe from astra coupe?
Uprising
Re: Calibra Window
Theres nothing that im aware of that would fit. so you would need to make your own glass and runner system. I think the door-strap setup and oem window winder(assuming you use it) would get in the way quite a lot (from memory) so its going to need quite a lot of thinking to get the mechanism to be functional..
Re: Calibra Window
the quarter window gives the rest of the window stability with out it the glass would wobble about and not seal
Re: Calibra Window
you're better with the quarter window even if you
could convert it,it saves alot of draught blowing on
your face when driving.I would just leave it mate
