Digi Dash Transducer
Hi Guys,
I have been flicking through the old posts on the digi dash. Does anyone know if you can still obtain the transducers without buying a new dash?
Any help would be gratefully appreciated
Re: Digi Dash Transducer
sometimes on ebay but there are 2/3 different types/codes
Thanks for that is there anyway of knowing which code goes with which unit. I suppose it easier to just buy a digi dash supplied with the transducer,
Thanks again
Thanks again
that would depend on what you car/engine your trying to fit it to ..also what digital dash
Hi,
I'm Running a calibra 16v and the digi dash is from a mk2 astra gte
I think its an AK code ...cant find the list I had of them, but there should also be a switch on the rear of the dash to change the pulse of the signal .8 to 16 I think
Cheers Fraz
I've seen a digi dash going cheep, its working, has the connectors the only thing missing was the transducer, if I know I can still get one I would'nt mind doing the conversion.
Many Thanks
Many Thanks
