Digi Dash Transducer
by sparkyjohnmarky » Mon Jan 07, 2013 11:40 pm
Hi Guys,
I have been flicking through the old posts on the digi dash. Does anyone know if you can still obtain the transducers without buying a new dash?
Any help would be gratefully appreciated :D
Re: Digi Dash Transducer
by matty0785 » Tue Jan 08, 2013 1:00 am
sometimes on ebay but there are 2/3 different types/codes
by sparkyjohnmarky » Tue Jan 08, 2013 5:02 pm
Thanks for that is there anyway of knowing which code goes with which unit. I suppose it easier to just buy a digi dash supplied with the transducer,
Thanks again
by Fraz » Tue Jan 08, 2013 6:15 pm
that would depend on what you car/engine your trying to fit it to ..also what digital dash
by sparkyjohnmarky » Thu Jan 10, 2013 9:03 pm
Hi,
I'm Running a calibra 16v and the digi dash is from a mk2 astra gte
by Fraz » Thu Jan 10, 2013 10:37 pm
I think its an AK code ...cant find the list I had of them, but there should also be a switch on the rear of the dash to change the pulse of the signal .8 to 16 I think
by sparkyjohnmarky » Thu Jan 10, 2013 11:55 pm
Cheers Fraz
I've seen a digi dash going cheep, its working, has the connectors the only thing missing was the transducer, if I know I can still get one I would'nt mind doing the conversion.
Many Thanks
