Do Irmscher numberplate surrounds fit inside Irmy panel?
I want to use these...
Within the Irmscher / Hella type rear light panel (bit between rear lights)
Can anyone confirm it will fit?
Thanks
Thanks
Re: Do Irmscher numberplate surrounds fit inside Irmy panel?
Just popped out and measured the flat plate area on mine.
it's 540 x 150mm.
Hope that helps.
it's 540 x 150mm.
Hope that helps.
Thanks! I've seen a pic of the two fitted over on migweb and I'm not a fan. Think I'll just stick with the bit between the lights!
