aerial rubber
aerial rubber
Has anyone of you already found a solution to the rubber aerial part that dries up and cracks, as it is not available at the dealership UNLESS you purchase a complete aerial unit.
Anyone found a rubber that fits.
AND NO
No adhessives or other non original ways.
AND NO
1llusion
Re: aerial rubber
That's the one I used and it works ok but you do need to put it in boiling water.
Re: aerial rubber
Mine's starting to look a little tired so I will order one of these for when I need it.
Re: aerial rubber
done mine with one of these last year
aerial rubber
Ditto
