Cracked Dash
Cracked Dash
Anyone got any suggestions what i could do with a crack in the dashboard up against the windscreen, its doing my head in as its right in the middle.
Baldypie
Three choices [img]/smile.gif[/img]
1, Get a new part form Vaux, take out the whole dash and fit new part, if vaux still do that part !
2, Remove windscreen and fit part.
3, Get a new cover from <a href="http://www.lenk-opel-tuning.de/" target="_blank">http://www.lenk-opel-tuning.de/</a> which goes over the cracked one.
<!--QuoteBegin-RobbieV+--><div class='quotetop'>(RobbieV)</div><div class='quotemain'><!--QuoteEBegin-->Three choices [img]/smile.gif[/img]
3, Get a new cover from <a href="http://www.lenk-opel-tuning.de/" target="_blank">http://www.lenk-opel-tuning.de/</a> which goes over the cracked one.<!--QuoteEnd--></div><!--QuoteEEnd-->
or 4. live with it ...like the rest of us
<!--QuoteBegin-Fostersice17+--><div class='quotetop'>(Fostersice17)</div><div class='quotemain'><!--QuoteEBegin-->Mine is cracked in a few places,but im getting my windscreen done soon,has a few chips in it,will replace mine then.<!--QuoteEnd--></div><!--QuoteEEnd-->
Good luck to you! I planned to do this with my V6 when I had the screen replaced, found a guide (on cavweb? or somewhere...) but ended up I only had an afternoon to do it or I'd be left without a windscreen overnight(!) so in the end I decided it was just too big a job for the time. Removing the dash completely looks a real pain in the arse, you might get away with removing key bits like glove box, airbags, steering surround and centre consoule then loosening the main dash and shuffle it forward a little to get the new part in...?
Steve
Steve
icewizard
do you want to fix it like this?
if yes, stay tuned after the breaks.
we're back!
So you want to fix your Dashboard
i had a new dashboard with a good non cracked windshield vents...
To take it of i had to break the supports, so i ended up with something "close" to a "cover" from lenk... That gave me an idea.
i took away my old vents, with lots of pacience, some tiny pieces are still glued in the dashboard, but that didnt stoped me, i used a rubber based glue to glue the big part, and contact glue to glue the parts that sit near the vinyl. i also had to glue the "covers" from the left and right side, the result? no noises , and no one would notice that has been fixed.
Case closed
![Image](http://www.furnation.com/unusual/redcalibra/17.jpg)
![Image](http://www.furnation.com/unusual/redcalibra/18.jpg)
![Image](http://www.furnation.com/unusual/redcalibra/22.jpg)
we're back!
Case closed
DeepSnoozer
i took the dash out of one of my cars, in fact the dash is in my kitchen at the moment, it is very painstaking job to do, realy not worth the effort, would be better just to cover it with something, but its your choice<!--QuoteBegin-Baldypie+--><div class='quotetop'>(Baldypie)</div><div class='quotemain'><!--QuoteEBegin-->Anyone got any suggestions what i could do with a crack in the dashboard up against the windscreen, its doing my head in as its right in the middle.<!--QuoteEnd--></div><!--QuoteEEnd-->
tommycon45
Mines also cracked in a few places, to be honest i dont really notice it, but i think the best options to cover it... That link doesnt work for me either, would like to see what this cover is like???
