digi dash?!?!?
by 1llusion » Thu Nov 01, 2007 8:04 am
any more questions, please do ask LOL
I have been searching for all sorts of answers on this subject for years now
1llusion
by Fraz » Thu Nov 01, 2007 3:05 pm
well done ...question how to get the "F" light out and get the range function working on the board compter ??
by 1llusion » Thu Nov 01, 2007 4:39 pm
The range function on the Trip computer is calculated by the Speeddo signal cable.
You have to make sure the Blue/red wire is connected to the blue/red wire of the trip comp.
The F on your Opel Vectra A 2000 Digi Dash is a failure signal.
Meaning there is something wrong with either the dash, or the wiring.
Did you connect the Check Control correctly?
1llusion
by Fraz » Thu Nov 01, 2007 5:39 pm
well yes the check control all goes out apart from the airbag light as that needs reset
all the functions on the F/C work (and range worked before fitting the dash) did hear that the chip needs reprogrammed though as its not the right one for the car ..its an senator one , as the original chip would not work in MPH and gallons
also heard that both the F/C and dash chip have to be the same programme number??? but not that sure
also do you know away to change the dash colour?
by 1llusion » Thu Nov 01, 2007 10:17 pm
it is in german, but pics do say a lot.
The only way to get it realy blue.
http://www.rotanes.de/ninamama/
1llusion
by damo1 » Mon Dec 17, 2007 9:36 pm
yep
damo1
Re: digi dash?!?!?
by gsi2000i » Fri Jan 28, 2011 1:55 pm
Could you send me that german site and all the information you have regarding wiring og fitting that dash?
I bought one of this dashes and I'm planning to fit it into my Kadett GSI. Thanks!
gsi2000i
Re: digi dash?!?!?
by Fraz » Fri Jan 28, 2011 8:32 pm
what gereman site???
