Track car winter project
Re: Track car winter project
sorry mate , i ment to say when you test fitted the tunnel from the omega , you can see the gap between the omega tunnel and the floor of the calibra, the bnit that i said you would have to fill in
yee cool what dis you do with the ani roll bar ?
re located it,by 180 degrees,so it was back to front ,so the bar was at the front of the car going to the back
was that not what i said MrD
Allys Cally wrote:was that not what i said MrD
see your not just a big ugly block lol
ever dog has his day, yesterday was obviously mine
good work guys ...you should be contestants on scrapyard challenge lol
well and i managed to stay of the cider long enough to get down the garage and get some more done, we now have the bulk head and floor cut we have also got the engine box steering rack subframe and down pipes in position, next job is to get the rear diff in so we can line it all up 100% then its out with the welder, ill get some pics up tomorrow ( the battery is flat in the camera )
very good going
- Club Member
well we have been lazy boys but got back down the garage today, we now have the rear diff on and just waiting for the the drive shafts,
next job is to get 115mm added on to the prop then we can weld up the tunnel and bulk head, we also need to convert the cable clutch pedal into a hydraulic one (if any one has done this your help would be good) we know what we need to do but there must be an easy way around this, then it should pretty much sorted apart from talking a Geordie fellow to pop up and help fit and paint the dtm body kit
Any more progress on this
limited progress with me being out in spain more than being here hasnt helped and with the shows now starting i cant see much being done till end of summer
