nice fault codes...c20let :(
Think the MAF sensor is shot then. Not sure about barometric pressure high.... Air intake sensor can be changed. Just wondering if all are knock on from MAF issue.
![Image](http://i978.photobucket.com/albums/ae269/seanoturbo/faultcodes24511.jpg)
Sean
SE5 Turbo
LE 07
LE 16
Turbo
Another Turbo
Se7
V6
16V
8v
SE5 Turbo
LE 07
LE 16
Turbo
Another Turbo
Se7
V6
16V
8v
- Club Member
Re: nice fault codes. ??
I presumes it is the motronic 2.7 module your using in the snap on scanner, just the P codes are not the usual read out
Re: nice fault codes...c20let :(
Yeah it had trouble connecting. But thats happened before Can always re-check on a Tech1 at vauxhall. I feel the symptoms of the airflow sensor though, runs rough usually when warm occasional pop on cold and noisy when hot. So a second look wont hurt.
Sean
SE5 Turbo
LE 07
LE 16
Turbo
Another Turbo
Se7
V6
16V
8v
SE5 Turbo
LE 07
LE 16
Turbo
Another Turbo
Se7
V6
16V
8v
- Club Member
and rather interestingly it doesn't match the codes on topbuzz at all ![Doh! :doh:](./images/smilies/eusa/doh.gif)
Sean
SE5 Turbo
LE 07
LE 16
Turbo
Another Turbo
Se7
V6
16V
8v
SE5 Turbo
LE 07
LE 16
Turbo
Another Turbo
Se7
V6
16V
8v
- Club Member
I get 31 which is normal when the car is off. it runs a continuous 12 on idle.
Sean
SE5 Turbo
LE 07
LE 16
Turbo
Another Turbo
Se7
V6
16V
8v
SE5 Turbo
LE 07
LE 16
Turbo
Another Turbo
Se7
V6
16V
8v
- Club Member
any ideas re my car lol
I had a similar issue recently where no faults codes were coming up but on the way home one night the eml did come on and turned out to hall effect sensor, all the other times it was rough once warm nothing ever came up
Phantom
No registered faults,
Boost cut was due to oil in the MAF pipe.
The boost cut doesn't register on the ECU.
No EML but no bother now as she is sold.
Sean
SE5 Turbo
LE 07
LE 16
Turbo
Another Turbo
Se7
V6
16V
8v
SE5 Turbo
LE 07
LE 16
Turbo
Another Turbo
Se7
V6
16V
8v
- Club Member
Users browsing this forum: Google [Bot] and 28 guests
