Coil Spring Gone
Coil Spring Gone
went to replace the front coil spring rubber seats and found the coil broken. The car didn't look or handle any differently
- Gold Club Member
Re: Coil Spring Gone
it looks like its only the pig tail that has broken off so you wouldnt feel or see a great diffrence, but better off fixed
v6 steve wrote:it looks like its only the pig tail that has broken off so you wouldnt feel or see a great diffrence, but better off fixed
It was only the pigtail.
Fitted some at the new springs that dropped the car 40mm, but they gave the car too much negative camber at the back for my liking. So I made some platforms from 6mm conveyor belt rubber to raise the back and reduce the negative camber
- Gold Club Member
vec 160 wrote:v6 steve wrote:it looks like its only the pig tail that has broken off so you wouldnt feel or see a great diffrence, but better off fixed
Platforms like these???
http://www.ebay.co.uk/itm/Holden-Calibr ... 20c10a4c06
http://www.ebay.com.au/itm/280799742248 ... 1438.l2649
http://www.ebay.co.uk/itm/Holden-Calibr ... 20c10a4c06[/quote]
Yes, but cheaper. When the weather gets better I am going to move the pivot point on the arms to reduce the camber
- Gold Club Member
