Sharpen up your steering - poly track rod bushes £24 inc p&p
Just thought some of you would appreciate this link.
Not seen many people running these but should be a good modification to reduce play in the steering!
£24.04 delivered
http://www.priracing.com/product.php/17 ... rod-bushes
£24.04 delivered
Re: Sharpen up your steering - poly track rod bushes £24 inc
might treat myself in the new year...
Abit of a bump
Ive been looking at these....anyone now got them, how easy are they to fit and is there a good improvement with them?
They are easy to fit, just press them in and out. Took me about 3 minutes each side.
And yes it was a brilliant different. It eliminated about 80% of the play in the steering.
Chavtastic wrote:They are easy to fit, just press them in and out. Took me about 3 minutes each side.
Did you fit them with the arms on the car or taken off?....they sound good though
Yeah I did, but I had the arms off anyway to be fair.
Not sure you'd manage it in-situ as you need a press ideally. Having said that, a G-clamp with a socket might do it (something like a 19mm looks about right size)
Just bought a set
They must have reduced them slightly as it cost me £23.38 delivered
Me too!!!!
I will get my Calibra finished one day promise!!!! ITS FINISHED !!!!!
Just wondering on fitment...haynes says to use a new locking plate on the inner tie rod bolts and new nyloc nuts on the track rod ends.....is is 100% necessary?
MadOnVaux! wrote:Just wondering on fitment...haynes says to use a new locking plate on the inner tie rod bolts and new nyloc nuts on the track rod ends.....is is 100% necessary?
Mate you are always meant to replace nyloc nuts once you
take them off.
craigyboy wrote:MadOnVaux! wrote:Just wondering on fitment...haynes says to use a new locking plate on the inner tie rod bolts and new nyloc nuts on the track rod ends.....is is 100% necessary?
take them off.
Ok, but what about the locking plate?
usually the locking late will snap at one or more points, so if your that worried you should change it
MadOnVaux! wrote: I've been looking at these... Anyone now got them, how easy are they to fit and is there a good improvement with them?
I've had them for a Year now...
Scroll down to the bottom of the page for some pics...
viewtopic.php?f=16&t=45499&start=60
EddeyDancer wrote:MadOnVaux! wrote: I've been looking at these... Anyone now got them, how easy are they to fit and is there a good improvement with them?
The ones you have are for the anti-roll bar links Eddey...the ones we are on about are for the steering, they fit the inner tie tod, connected to the rack
Any excuse for a bit of powdercoating
