been very very busy!
Re: been very very busy!
Cheers for the comments guys,i think it definetly
freshens it up a bit
At least the Corrosion situation, is being dealt with!!!
It's always good to know, what the condition of the Car is in...
Helps put your mind at ease!!!
Good work there mate. Looks much better
Front end all stripped again.putting back on lower arms
with ordinary rubber bushes,fitting new bilstein shocks
and apex springs.heres hopping the rides alot smoother
planning to post some pics tomorrow
I'm keeping the poly anti roll bar and drop link bushes
eh this is not the for sale section
got the new front springs,ready to fit
painted new lower arms
fitted new bushes to the track rods
also fitting new shocks
and also top strut mounts and bearings
Picking up two new front bearings today,my local garage will
press them in for me.When I stripped them off one of them
felt a bit worn.
felt a bit worn.
Thats the car all back together now.poly bushes
definetly not meant to be used on Glasgow roads
be good on the Highland roads though .....well the way we tend to drive them
im going for new std ones im sure they will be better than 15 year old ones and not as hard as poly ones as for the front arms they only last a year or two anyway
Even then you can still replace the standard bushes
saves buying a whole new arm
craigyboy wrote:Even then you can still replace the standard bushes
just as cheap doing the whole arm and much easer
True ,just noticed you can get new arms less than the price of
four bushes
four bushes
