overhaul begins
Re: overhaul begins
Thanks for that Fraz.For the windows can that just be doubled
up with the lock cable?
Re: overhaul begins
I would think the alarm would have a timed output just for windows ..if you use the lock it will be only a very short pulse so the window would only go up a wee bit ...not all the way
Re: overhaul begins
Thats true.Oh well I dont think this alarm has this facility
Re: overhaul begins
what alarm is it
Re: overhaul begins
its a E50 car alarm system .The make is Kodinis Raktas
Got it off Ebay.It says on the box that one of the features is window
close output but I couldnt see it in the wiring diagram.I'll check it again
tomorrow.
tomorrow.
Re: overhaul begins
Fraz wrote:best place would be the central locking relay in the drivers kick panel
colours
lock is brown white
unlock is brown black
I think thats ocrrect but easy to check all you do is bare a wee bit and put an earth wire to the wire and see if it locks or unlocks
think the the window lift is also brown black if you want that to work as well ..sam ething works on a earth pulse
I checked the alarm earlier and the locking control wires are switching in positive
so I am going to have to add in two relays for the alarm wires to control the relays
and they can switch the two negatives to the central locking relay.
Oh the joys of buying from Ebay
Re: overhaul begins
would sell it and buy another as it sounds a load of rubbish ..I just fitted one of these does what I want. locks the doors and put the windows up
Re: overhaul begins
Fraz wrote:would sell it and buy another as it sounds a load of rubbish ..I just fitted one of these does what I want. locks the doors and put the windows up
what make was the alarm you fitted Fraz?
Re: overhaul begins
Thats the total closure system all working now and changed the
pump for the water scooshers today.Next job to get it mot'd and
get the bonnet resprayed
Re: overhaul begins
it should be looking good when you get her finished bud.
Re: overhaul begins
Quick update.fitted new H T leads to match
the rest of the engine bay
got interior completed,just needs cleaned
Heres how its looking now.Just needs motd and the bonnet resprayed
Re: overhaul begins
That's looking good
Re: overhaul begins
Looking well mate
Users browsing this forum: No registered users and 239 guests
