rear brake size...97 v6(se9)
Re: rear brake size...97 v6(se9)
calipers are different. 284mm discs have 54mm piston calipers, 288mm discs have 57mm piston calipers. and brake pads also are different. what can or cannot be swaped - I don't know.
U_V6
The top picture from a box is the part number for a pair, the number stamped on the disc must be the number of a single disc.
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
top number says disc set rear C20LET C25XE X25XE
The one on the dsic I make out to be 9037551..no part
then tried a 8 on the second 5 and also a 9 ......no part
