Oh Sod
Oh Sod
The alternator is on it's way out but it is 13 years old.
Re: Oh Sod
Easy fix ................... just get somebody else to do it
Re: Oh Sod
I'm not doing it I have a son for that
Re: Oh Sod
its easy as iv done mine 3 times now
it should come down and out the driver side if you take the drive shaft out
it should come down and out the driver side if you take the drive shaft outsteve
Re: Oh Sod
aye but if you take the oil pressure sensor out it will come out without dismantling the drive shaft
Re: Oh Sod
tazz666 wrote:aye but if you take the oil pressure sensor out it will come out without dismantling the drive shaft
result
Re: Oh Sod
Mark1 wrote:I'm not doing it I have a son for that
Thats what sons are for
Re: Oh Sod
got mine out without removing either but it was a bit of a juggle, some are bigger than others, mine was the 100 amp one.
marko
Re: Oh Sod
mine is a 120 amp and i know it comes out with the oil pressure sensor removed as i had a few alternator failures,
