Where to put axle stands on the Calibra?
I have tried searching for this but i cant find anything...
I just think i'm putting them in the wrong place......on the front i put them just behind the arch, on abit with 2 holes in.....and on the rear nowhere looks right....i have had them on the subframe bush bit but its slipped off there in the past, and i dont think the trailing arms are a good idea either.
So is there a proper safe place to locate them?
BTW i am using a trolley jack tift the car, using the sill jacking points, but using a block of wood with a groove cut into it on the jack 'foot'
Re: Where to put axle stands on the Calibra?
Front and rear really
