Gone for MOT!!
Gone for MOT!!
MOT tomorrow.....not 100% sure how it'll do....if anything I hope it'll only be brake lines or flexy's, although front balljoints maybe abit suspect?
Swapped my HID's for standard bulbs and put my cat back on though
Fingers crossed!!
Fingers crossed!!
Re: Gone for MOT!!
Have you done your usual simple checks? All lights wipers washers are working ect
- Club Member
Re: Gone for MOT!!
good luck....mine passed yesterday
Re: Gone for MOT!!
stevo turbo wrote:Have you done your usual simple checks? All lights wipers washers are working ect
Yeah did them Steve, and all ok....although i did that once on my Cav Diplomat, and from leaving home and getting to the MOT station, the effing numberplate lamp blew!! lol
Re: Gone for MOT!!
Fraz wrote:good luck....mine passed yesterday
Thanks Fraz
Re: Gone for MOT!!
Cheers folks
Just been and picked it up.....it passed, 4 advisories though, nowt major.
Quite a big bill (£334) as i tell them if it needs anything to just do it and it needed a balljoint so they put a new arm on, new track rod end, and they fitted my rear anti roll bar links, welding under front arch (where they all go!), plus they had to unseize track rods for alignment.....bloody old cars eh lol
Re: Gone for MOT!!
just under the washer bottel
Re: Gone for MOT!!
If you take the wheel off, its sort of just under where the track-rods go through.
Under the bonnet where the arch meets the bulkhead it creates an area that grit and dirt build up, and it rots through.
Re: Gone for MOT!!
Heard of this,never seen it before-Touch wood I won't need to weld mine
Re: Gone for MOT!!
My 1st Calibra went both sides, all 3 of my Cav's went there and this has gone too....passenger side area is accessible to clean out and waxoyl, but drivers side is hard to get to.
Re: Gone for MOT!!
Mine seems to be full of old engine oil that has leaked over the years lol
- Club Member
Re: Gone for MOT!!
stevo turbo wrote:Mine seems to be full of old engine oil that has leaked over the years lol
Hell it must've sprayed quite away then...they are a distance from the engine that mere leaks wouldnt get to.
Users browsing this forum: No registered users and 56 guests
