polish removal
Re: polish removal
by craigyboy » Sun Mar 17, 2013 1:38 am
what is the reason anyway? :think:
Re: polish removal
by Mark1 » Sun Mar 17, 2013 8:00 am
Vinegar in the water when you wash it.
Re: polish removal
by Fraz » Sun Mar 17, 2013 10:19 am
craigyboy wrote:what is the reason anyway? :think:
your better sometimes to strip all layers of protection that have been applied over the years and get down to the paint, you can then give the paint more correction and remove any marring or marks left by a polish or wax or water that has not been removed corretly, or some tar that has been polished over rather than removed
I do it twice a year but does take a day or two to get it all done
Re: polish removal
by v6 steve » Sun Mar 17, 2013 10:57 am
sounds about what i was going to say Fraz apart from the twice a year bit :lol:
Re: polish removal
by Fraz » Sun Mar 17, 2013 11:26 am
well I do it around Aprl to get all the winter stuff off and about October to give it protection over the winter ...on the plus side after that a quick wash is all thats needed and the beading of water lasts months
bad side is it does usually take a full weekend to do t all ...my routine
Snow foam car
Rinse
Dry car with towel
Take all wheels off and give them a good wash and then leave to dry
Go over car with a product called "wax off" does what it says a will remove all wax or sealant
Wash car with a mixture of G101 and do any or the badges/grills with a soft brush
Rinse and dry
Then apply Tardis ...a Tar remover and go over full car making sure all tar spots removed
Rinse and dry
Now do same to the wheels ..And dry and leave
Back to car and now apply IronX .......a product to remove any iron contaminates
Do same with the wheels
Rinse car and wheels …allowing about 10>15 minutes for ironX to work before rinsing
Snow foam car again and wheels and then rinse
Use a clay bar and go over the car and if needed the wheels (using the used clay from car for wheels)
Snow foam and rinse
Wash car with a good car washing product …twice ..wheels also
Dry with a good towel or 3
Apply a paint correction polish .I use few types but Super resin polish is good , I do it twice ..try not get any on the black trim
Apply 2 coats of wax (or whatever protection you want) I use Collinite 476 and you should wait an hour at least between coats …so good time for lunch/dinner
Clean all the wheels arches using G101 and I then apply Barebones from Chemical Guys, refit the wheels
Clean all black trim and apply some protection to them
Clean all the windows
And then start on the interior
Oh and I do the engine bay area and around the boot as doing the rest of the outside
Re: polish removal
by v6 steve » Sun Mar 17, 2013 2:12 pm
when can i book the girls in ? ill dig out the drive while your at it :whistle:
Re: polish removal
by Mark1 » Sun Mar 17, 2013 2:17 pm
Fraz wrote:well I do it around Aprl to get all the winter stuff off and about October to give it protection over the winter ...on the plus side after that a quick wash is all thats needed and the beading of water lasts months
Snow foam car
Rinse
Dry car with towel
Rinse and dry
Rinse and dry
Snow foam and rinse
Sounds about right
Re: polish removal
by Fraz » Sun Mar 17, 2013 2:42 pm
v6 steve wrote:when can i book the girls in ? ill dig out the drive while your at it :whistle:
well I may get one done in a weekend ..if your wanting it done while your playing with the digger ..no problem
