Rear Sway Anti-Roll Bar
Have many have Upgraded theirs, and what are you comparisons to the Standard??
I recently chatted to the actual manufacturer, who used to supply them to White Line...
I got some 'Custom Made Rear Springs' from him yesterday, and he certainly knows a lot about the Calibra Suspension
Re: Rear Sway Anti-Roll Bar
you can get the bigger Vauxhall rear anti roll bar (sway bar to you) I think its 22mm ...but have never seen one
only other one was the Whiteline from over your way, but they have stopped producing them now.
Did try to get one of them a while ago but none are around ...does this person still do the rear sway bar then?
Fraz wrote:you can get the bigger Vauxhall rear sway bar, I think its 22mm, but have never seen one
Did try to get one of them a while ago but none are around, does this person still do the rear sway bar then?
Correct, the Rear Sway bar is 22mm from what he told me...
He used to supply to Whiteline, who were only a 3rd Party Supplier...
That's why they say that, they no longer produce them...
Yes, he still makes them, and Rear Camber Kits and more...
I'll get some more details, of what exactly he makes and how much they cost...
