What is best donor Saab?
by Chavtastic » Fri Oct 03, 2014 11:53 am
Right I need a B204 turbo engine for my Calibra, and the Saab aluminium wishbones (and matching anti-roll bar) to suit a Calibra as these give 2.5 degrees camber and reduce unsprung weight, which is ideal for the track.
Would I be right in thinking a Saab 900 2.0 turbo (1994-1998) would give both of these?
Would the engine mount from that car fit the Calibra? (as it's based on the same platform)
Thanks in advance
Re: What is best donor Saab?
by KERR_SE9 » Fri Oct 03, 2014 11:21 pm
Yeah 900 or early 9-3 as it has to be pre 2001 for it be a 204 and not 205 etc
by Chavtastic » Sat Oct 04, 2014 1:33 pm
Thanks John do you know if those cars have the alloy wishbones?
by DanSE4 » Mon Oct 06, 2014 4:56 pm
The 9-3 (2000 'W') I was under this weekend looks like it has the alloy wishbones.
Didn't do any comparisons as they are to remain in place to keep the Saab "rollable" but visually they look like a direct fit to a Calibra.
Calibra SE4 3.2 V6 + F28
A Couple of German Cars!
by DanSE4 » Mon Oct 06, 2014 5:02 pm
These ones I think.
by Chavtastic » Mon Oct 06, 2014 7:47 pm
They are the puppies! Apparently you need the anti roll bar too from the Saab
by v6 steve » Mon Oct 06, 2014 9:10 pm
didnt you already do this to one of your calibras Ben
by DanSE4 » Tue Oct 07, 2014 10:05 am
Chavtastic wrote:Apparently you need the anti roll bar too from the Saab
Could be where the anti roll bar drop links connect to the wishbone, the locating holes may be in a slightly different place. I'll take a closer look this Saturday.
by Chavtastic » Tue Oct 07, 2014 4:11 pm
Yes Dan that's what I've read
v6 steve wrote:didnt you already do this to one of your calibras Ben
No mate I think I got the wishbones but realised they needed the ARB
