Turbo repairs begin!
Re: Turbo repairs begin!
I have owned 3 mk4 and it's a wheel from one one them! Its all looking good so far dude! You going to be ready for the 22nd you think?
- Club Member
Steveboy I'd bloody better be after £s I've spent!!-It has a megasquirt ecu, Standalone management, What would you like a picture of?
It's a cut&join job, it uses a ford focus coil, external trigger wheel for crank sensor and hardly any sensors,pretty basic stuff,until you get a wiring fault
Woohoo! Just been on the phone to the engineer who's building my engine, I get it back on thursday,Can't wait- Just spent tonight fitting braided hoses and wiring up my afr/boost gauge and pod, Pics asap
Well finished my brakes off this morning, and just got the engine back and prepared to fit,Cleaned up gear/transfer boxes Subframe off and car as high as I can manage, pretty tight but it's under just, So I may be running by tommorow!!
Couple of pics
Couple of pics
try not to break it this time
Well it's in an on it's mounts, tommorow will tell!
Well just home from pulling a mammouth shift on car, 95% of the way there, Still got aux belt/power steering pump/ few connections and gear/tx/diff oil to change, Hopefully should be running by the morning, then spend next week running in, Russ paton will be mapping it next friday:- , Looks like I got my measurements just right when fitting the wideband lamda (Look at clearance with tx box!!)
YES!!! She runs, Sounded like a bag of spanners at first, but sounding fine after heat built up, tappet or two still sticking though, and there all new!!
Pics tommorow, Lots of driving ahead of me this week, have to do 300-400 miles before mapping on friday
bring it down and ill do some for you
Just back from putting the first 250 miles on her, looks promising now, Oil change in morning then more painfully slow driving, Oh cheers for header tank steve!
Still getting noisey lifters here and there
how did mapping go? im still not built yet
- Club Member
Users browsing this forum: Bing [Bot] and 1 guest
