v6 rev limit
Re: v6 rev limit
by Allys Cally » Mon Aug 20, 2012 6:40 pm
tc- traction control, the tc unit sits between the throttle body and inlet manifold
Re: v6 rev limit
by chriskoi » Mon Aug 20, 2012 7:27 pm
My TC light is on, (to dear to fix :cry: ), but it still revs through range :?
chriskoi
Re: v6 rev limit
by Allys Cally » Mon Aug 20, 2012 8:03 pm
to be fair my TC has never worked either, had the butterfly removed and took the bulb out the dash. problem solved :mrgreen:
Re: v6 rev limit
by chriskoi » Mon Aug 20, 2012 8:34 pm
Nice one,but i did something little more tech.
I cut out a warning light size piece of black insu tape and stuck over it ! :lol: :oops:
chriskoi
Re: v6 rev limit
by smrw » Thu Aug 23, 2012 4:18 pm
OK - I've fiddled with the TC motor. With the engine off the connecting lever can be moved smoothly though its travel. With the engine ticking over it moves through about 5 degrees and then I can feel it coming up against the tip of a rotating cam or similar inside the motor stopping further movement - the lever vibrates as the motor rotates. Any help?
While I'm in TC territory, I had assumed that the traction control was switched on by means of the button near the base of the gear lever. Research into the manuals I have suggests that I have that the wrong way round, and that TC is ON when the car is started. The TC light comes on if I then press the button. It does not flicker at any point to suggest a fault.
-smrw
smrw
Re: v6 rev limit
by Mark1 » Thu Aug 23, 2012 5:01 pm
TC is on all the time, you do need to press the button to switch it off.
Re: v6 rev limit
by smrw » Thu Sep 06, 2012 4:40 pm
It has been suggested to me that it could be the fuel pump. That fits most of the symptoms - like the limiting when I try to accelerate - and the temperature bit may just be that the hot day pushed a poorly pump over the brink. I'll do some checking up.
SMRW
smrw
Re: v6 rev limit
by smrw » Sat Oct 06, 2012 4:48 pm
I have replaced the fuel pump and filter. No difference. I now have a spare (if used) in-tank pump and filter. The next thing I shall attack is the throttle potentiometer. Watch this space!
-smrw
smrw
Re: v6 rev limit
by smrw » Sat Oct 06, 2012 7:30 pm
Still in Southampton
-smrw
smrw
Re: v6 rev limit
by Callyman » Sat Oct 06, 2012 10:05 pm
Mark1 wrote:TC is on all the time, you do need to press the button to switch it off.
That would depend on who you are. :whistle:
Re: v6 rev limit
by smrw » Wed Oct 10, 2012 5:07 pm
Throttle pot made no difference - if anything it's worse. Just aout ticks over once its warmed up a bit but any amount of throttle causes it to misfire. Can't even pull away in it now!
-smrw
smrw
Re: v6 rev limit
by vec 160 » Wed Oct 10, 2012 5:31 pm
You could try changing the coolant temperature sensor as the problem seems to come about when your car is warmed up. They only cost about £12.
Make sure you don't buy the temperature sensor for the gauge in the car which has a single connector on it
