Compression test on the se2
Re: Compression test on the se2
by GreyDJ » Fri Dec 28, 2012 1:20 pm
I'd be spinning the engine with all the plugs out.
Given that it is measuring the pressure in the cylinder with the valves closed not in the inlet tract, why would the throttle position make any difference?
Were the tests run dry or with oil in the cylinders?
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
by Callyman » Fri Dec 28, 2012 1:34 pm
The throttle being open (only reason i can think of) is so when the piston drops and inlet valve is open the chamber will get the max amount of air possible (therefore better compression the more air you get) if the throttle is open.
Just a thought.
by GreyDJ » Fri Dec 28, 2012 1:38 pm
OK.
I have always run the test with it closed but as the conditions are the same for all cylinders a comparative test between them should be valid.
by GreyDJ » Fri Dec 28, 2012 1:49 pm
Yes, I suppose with everything cold the air going in is much denser than in a running engine with hot inlet tract.
by Fraz » Fri Dec 28, 2012 3:14 pm
GreyDJ wrote:I'd be spinning the engine with all the plugs out.
you would do a wet test after getting a low reading
by GreyDJ » Fri Dec 28, 2012 3:25 pm
Out of curiosity I do both tests if I get more than about 5% difference, it doesn't take very long and I use Redex not oil on a cat'd engine. I would certainly do both with those figures, you would normally expect one to be low, not high.
