Finally got the head off .
Re: Finally got the head off .
by Rob-se9 » Wed Nov 17, 2010 10:31 pm
Here some more pictures of the head work that i have been doing. As previously said about the patio slab, the head was only placed there for these pictures :)
And here are the pictures i took on the dreaded patio slab lol
Heres another picture for you, a front caliper assembly on an artic unit up against a pair of wire cutters 8)
by MarkV6 » Fri Nov 19, 2010 8:55 pm
ooo you do love your cardboard.... :P
[img]Rob's valves and hydraulic tappets stuck to cardboard[img]
And if you can get a 28 inch, 10 stud wheel to fit a Calibra.......... 8-)
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
by MarkV6 » Fri Nov 19, 2010 9:12 pm
It maybe the beer.... but,
oooohh nooooo
I now own this one.
by Rob-se9 » Fri Nov 19, 2010 9:21 pm
MarkV6 wrote:It maybe the beer.... but,
oooohh nooooo
Your scaring me now lol its gonna sound stupid but i guess its bad, im still learning :)
by Fraz » Fri Nov 19, 2010 9:29 pm
valve guides llok like they have cracks
by Rob-se9 » Fri Nov 19, 2010 9:30 pm
Fraz wrote:valve guides llok like they have cracks
Well bugger me, you guys have got some good eyes lol i guess i need to find some new heads :(
by Fraz » Fri Nov 19, 2010 9:33 pm
it may just be some dirt , hard to tell really and you can get them replaced if they are
by v6 steve » Fri Nov 19, 2010 9:33 pm
you can get the guide redone it only cost me £50 to get one head redone, it looks like the left hand one at the 2 o'clock is cracked
by Rob-se9 » Fri Nov 19, 2010 9:35 pm
I will check the heads again tomorrow just to make sure, thanks for spotting that guys :D
by v6 steve » Fri Nov 19, 2010 9:37 pm
it could just be the pics tho
by Rob-se9 » Fri Nov 19, 2010 9:39 pm
I hope so lol ill remove the rest of the valves and double check. ill post some more pictures up if i do find anything :)
by MarkV6 » Sat Nov 20, 2010 5:05 pm
Rob-se9 wrote:i guess its bad, im still learning :)
I just though it was a funny picture :eusa-whistle:
Got a pair of 2.5 heads in the shed, but I haven't checked the guides... if they're ok and you need them, just shout :handgestures-thumbupright:
I now own this one.
by Rob-se9 » Wed Dec 29, 2010 8:21 pm
Hi guys and girls. Its been awhile since ive posted anything properly. Ive been busy the last couple of weeks and only resently had the time to rebuild the heads and sand the ports all down so there now nice and smooth ;) Heres some pictures of the progress.
A picture of one of the heads all skimmed and ready to go. I thought afterwards maybe i should of got the heads skimmed after i rebuilt them lol. Luckly i never marked any of them :D
One of the ports before i sanded it all down by hand :)
After i sanded it down, i worked from 80 grit paper down to 800 grit wet and dry. It looks very dull but its quite smooth :)
I also done a before and after shot with the exhaust valves lol
Mid-way through lapping the valves in. I left the valves free so i new which valve goes where. I then took the valves back out and washed the cutting paste off. After i dried them off i rebuilt them.
The ports in the bottom intake sandwitch plate and the centre section also got a good rub down :)
As you can see some of the casting is quite difficult to remove, but even with the marks visible the ports are 90% smooth :)
by v6 steve » Wed Dec 29, 2010 8:43 pm
did you get the guids done or where they ok ? the ports are looking good
by Rob-se9 » Wed Dec 29, 2010 8:50 pm
v6 steve wrote:did you get the guids done or where they ok ? the ports are looking good
the guides are fine mate, thank god lol.
