managed to clean a lot of oil up....
i did do a bit of a cleanup operation today but not as much as i wanted to get done, because dads powerwasher buggered about and because i had to do it on the grass with slates using trolley jack and scissor jacks .i gunked the bad areas of the block from under the oil filter and aroundn the bottom of the block and some of the wishbones.
the rest im going to have to get a steam cleaner and finish off with that but heres the pics:
before :
and after :
before :
and after :
Re: managed to clean a lot of oil up....
ohhh nice and clean!!
Not that much and Baz why aren't you going to Billing? AGAIN.
Mark1 wrote:Not that much and Baz why aren't you going to Billing? AGAIN.
come on Baz you o me a pint for the oil cooler so get down/up there one of the days at lest
baz just come you light weight lol
