Flywheel
Re: Flywheel
i would like to get a lighter one....
Re: Flywheel
i basically want to know what flywheel i would have coz there was one on ebay earlier goin at a bargain price (in comparison to spanking new ones) and i cant get to the engine right now too see...
Re: Flywheel
later type ...has pot fly wheel ...earlier one dont ....like in your other post
viewtopic.php?f=12&t=44751&p=462123#p462123
Re: Flywheel
i didnt know that, i only found out a few days ago that there was 2 different types of flywheel. Cheers fraz
Re: Flywheel
Jamesyboy wrote:i didnt know that, i only found out a few days ago that there was 2 different types of flywheel. Cheers fraz
you found out more than a few days ago ....unless you ignore what I wrote in the link above
Re: Flywheel
i did read it, and i just read it again just now, and its just hit me that yes, you have already told me. My apologies
Im wantin to get a lightened one, but i will wait until i have the right bargain staring me in the face. I was recommended getting one by c4libr4 to get one as it was one of the best investments he had ever made!
Re: Flywheel
just get the early one its lighter then the one you have
Re: Flywheel
How much lighter though?
Re: Flywheel
dont know go get one and put it on the scales
Re: Flywheel
std pot is aprox 9.5kgs
std flat is aprox 6.5kgs
a flat type helix cover is 4.3kg's
a pot type helix cover is 4.4kg's
just copied and pasted from migweb, after a bit of hunting.
there is like 3 kg difference!
so if i changed to the flat type, i would have to change what else?
The clutch.... anythig else?
Re: Flywheel
just the clutch
Re: Flywheel
or you could just drill loads of holes in the one you have too make it lighter
Re: Flywheel
now thats a bit of a silly idea is it not?v6 steve wrote:or you could just drill loads of holes in the one you have too make it lighter
Re: Flywheel
thats how they used to do it ...all be it with knowing what and where to drill the holes
