Failed
Failed
Today i was supposed to be changing my front top mounts but failed miserably thanks the the F'ing tie rod ends. ONce the nut was off the joint just would not split. tried hitting the threaded end up with a 4lb lump hammer, no joy. Cut the sodding thing thing off so once the leg was off we could heat it and hit the thing out. still no joy. The boy is now going to take the legs to work to use the press there, unless anyone has any good ideas on getting these stubs out.
Also will have to replace this rubber damper thing. Do vauxhall still stock these?
Bloody wish i hadn't started now
Still have the wishbone, new tie rods and cv boots to do. I hate my car right now, its nasty and not playing the game, still at least the drop links didn't snap
Re: Failed
have you tryed heating them now youv cut it off, the last time we did the struts we took the arms off at the rack to save us f*****g the ends, to be fare they are only £7/8 each so best repaced anyway
Re: Failed
Yep heated with them lying on the deck and nothing. Will be doing that next time me thinks. Live and learn and i'm getting too old for this sh!t. Lucky the boy is a HGV mechanic, he can do it all now lol
Re: Failed
why dont you call me??????????
i have two rubbers in the shed i think as for getting them out grind the other side out and place a nut on the other side,get your splitter out and do it up then hit it bloody hard.
if you do a good job it should fire out like a bullit and put a hole in your fence
vinny_69
Re: Failed
vinny_69 wrote:if you do a good job it should fire out like a bullit and put a hole in your fence
That sounds like experiance Vinny
Re: Failed
They had to go under the oxcycetaline torch until they glowed orange and even then they were hard to get out. Didn't call you as you were moving and the rubber stop things are order from Germany. Motor is still sitting looking sorry for itself in bits on the drive
Re: Failed
you could still have called me
i could have done with a rest anyway
and yes Andy i shat myself as it missed the greenhouse by about 4 inches
vinny_69
Re: Failed
Can i have one of your rubbers please, i've still to rebuild the legs and refit everything but the bl**dy nightshift is hindering. Cash and a cuppa waiting
Re: Failed
if i get the chance i will pop them round tomorrow for ya mate
do you need anything else?
vinny_69
Re: Failed
vinny_69 wrote:if i get the chance i will pop them round tomorrow for ya matedo you need anything else?
Cheers mate, i'm around all afternoon, my birthday, out early evening.
As for anything else this is a family site and Kylie is spoken for
Re: Failed
i would rather have Danni myself
ok if your not in i will chuck em over the fence or something
vinny_69
Re: Failed
Or leave them under the car
Re: Failed
Or both even, going to have to stop now i'm getting those thoughts. Not good at my age
