4x4 again
4x4 again
by Callyman » Fri Jul 30, 2010 10:59 pm
Put the new sports transfer box in today so all running 4x4 again as it should be. :band:
Getting the old one out was a pig as every bolt that was a tricky to get to had grotty threads and where tight all the way out.
Here's a tip if you ever need to fill a TX box with new oil.
Remove this bolt (seen missing) as this one and the lower one actually go into the inside of the casing and leaving it out will allow the new fluid to fill the box in less than 1 minute, as it allows the air to come out.
Also, if anyone has a gearbox and feels the gear change is a bit clunky, drop the oil and refill with EP75-80 oil.
My box only had about 1 litre in it, and was noisey and clunky, it's now smooth even when cold and very quiet.
Re: 4x4 again
by stevo turbo » Fri Jul 30, 2010 11:43 pm
good to see your back with your 4x4 dude. also on filling a txb box. i found the best thing was a fairy whashing up bottle. you can get a bit of pressure to push the fluid into the box also :D
Re: 4x4 again
by splinter » Sat Jul 31, 2010 1:02 am
Nice one Andy glad you got it all sorted :)
Re: 4x4 again
by Callyman » Sat Jul 31, 2010 7:34 am
Yes, the casing is from '92 and was actually built in may '08 according to the test data and warranty.
Again, with the gearbox now smooth it makes the car so enjoyable to drive, its even bettter than when I first bought it, so must always of been low.
Re: 4x4 again
by v6 steve » Sat Jul 31, 2010 9:05 am
good to see it all back together Andy :clap: now all ou need to do is give it a good run to run it in ill put the kettel on if you want :lol: see you in 6 hours
Re: 4x4 again
by Callyman » Sat Jul 31, 2010 9:18 am
Thanks steve. I'll get some cream yum yums on the way. LOL
Re: 4x4 again
by bodgetastic » Sat Jul 31, 2010 9:22 am
Good job Andy, those bolts can be a bit of a pain, ive been tempted to loose the tricky one a few times when putting it back together :lol:
I remove the bolt to the left of the temp sensor when filling, also acts as a level gauge when filling not that you can go too far wrong if using the vauxhall fluid
Re: 4x4 again
by Phantom » Sat Jul 31, 2010 12:22 pm
glad you got it sorted, you now know what a pain they are to do
on the plus side I managed to lift the gearbox and transfer box in one back onto the engine this time, just got to fill both nowwith oil then subframe back on then she's on the road again
Re: 4x4 again
by Callyman » Sat Jul 31, 2010 2:15 pm
Great news Andy, as you say I now know what's involved in changing one, and mine was 6' in the air.....Cant imagine how you do it at home. :clap:
