Oh Sod
Oh Sod
by Mark1 » Fri Oct 08, 2010 4:55 pm
The alternator is on it's way out but it is 13 years old. :(
Re: Oh Sod
by RobbieV » Fri Oct 08, 2010 4:58 pm
Easy fix ................... just get somebody else to do it ;)
Re: Oh Sod
by Mark1 » Fri Oct 08, 2010 5:02 pm
I'm not doing it I have a son for that :D
Re: Oh Sod
by v6 steve » Fri Oct 08, 2010 6:31 pm
its easy as iv done mine 3 times now :doh: it should come down and out the driver side if you take the drive shaft out
Re: Oh Sod
by tazz666 » Fri Oct 08, 2010 7:20 pm
aye but if you take the oil pressure sensor out it will come out without dismantling the drive shaft
:D
tazz666
Re: Oh Sod
by v6 steve » Fri Oct 08, 2010 7:28 pm
tazz666 wrote:aye but if you take the oil pressure sensor out it will come out without dismantling the drive shaft
:D
result :clap:
Re: Oh Sod
by Robs-se » Fri Oct 08, 2010 8:19 pm
Mark1 wrote:I'm not doing it I have a son for that :D
Thats what sons are for :lol:
Re: Oh Sod
by marko » Fri Oct 08, 2010 9:20 pm
got mine out without removing either but it was a bit of a juggle, some are bigger than others, mine was the 100 amp one.
marko
Re: Oh Sod
by tazz666 » Fri Oct 08, 2010 10:34 pm
mine is a 120 amp and i know it comes out with the oil pressure sensor removed as i had a few alternator failures, :oops: :D
tazz666
