traction control...... on or off?
I know its meant as a driver aid but is it actually usefull, does it sap power at all?
Im not exactly a boy racer but i do like a "spirited" drive now and again
How do you drive yours, ie on or off?
v6bob
Re: traction control...... on or off?
mine doesnt work so off for me
But given the choice would you still drive with it off?
v6bob
Don't have it, Don't need it.
When i DID have it I had it switched on unless i was on the way to get new front tyres then i had some smokey fun.
v6bob wrote:mine doesnt work so off for me
to be honest it wouldnt bother me, like Andy says if i really want to spin up my tyres i can.
traction controls for people with s****Y clutch control
seems to be a few that are broken, i must be lucky
think ill turn it off for a while though see how it goes.
v6bob
v6bob wrote:seems to be a few that are broken, i must be lucky![]()
Be careful on wet roundabouts.
v6bob wrote:Be careful on wet roundabouts.
ok, thanks
Going into and around them is fine, but power out of a wet corner with the load over the outside wheel and the inside tyre will spin up very very easily. V6 calibras are known for trying to go in a straight line when cornering fast/tight (on std suspension that is)
Stiff shocks can be worse in the wet.
I'd personally leave it switched on, unless you want to destroy your tyres.
ok, on in the wet off in the dry. but seeing as its wet 99% of the time in this country i might as well leave it permanently on
v6bob
mine works and its on all the time unless i want ti leave 11's down the road without it my car would be pritty hard to keep on the road
Just leave it on all the time.
I think that would probly be the wisest choice !
v6bob
