part number required *early check strap cotter pin*
as title...just been to dealers but they only show the later 10mm type bolt for door check straps.i need the early cotter pin type for a 92.anyone help?
k1nty
Re: part number required *early check strap cotter pin*
I'd have looked mate, but my EPC had a virus and Norton wiped the fecker!
CHECK LINK AND STRAP FITTINGS
90346767 1 60 912 SCREW, HEX.HD. C L1000001-C P1299999-P9299999
90462820 (1 60 914) SCREW, HEX.HD. NLS.- USE 9116434 1 60 918 C R1000001-C R9000001-
OPEL PARTS GREECE
early cars dont have bolts through.everyone comes back with same thing??
k1nty
You dont have a picture do you, i remember replacing something on my SE in that area. A picture might jolt the old memory. Is it the bolt holding it onto the door frame?
mk3 cavaliers used to use the cotterpin
tazz666
only shows a bolt for the Calibra but as Tazz said the Cavailer shows a pin
Part Number 9287242 PIN, STRAP TO CHECK LINK SUPPORT
Part Number 90195523 SLEEVE, TENSION, CHECK LINK STRAP TO SUPPORT
- Attachments
- Cavalier
- door strap1.jpg (19.76 KiB) Viewed 10785 times
- Calibra
- Check Strap 2.jpg (20.16 KiB) Viewed 10785 times
cheers lads,i ordered an early model cav one,doesnt fit.i will check if it was same pt number as yours fraz.the problem is the holes in the a_ post bracket are smaller than the ten milly bolt type as on later cars.check strap is obviously different too.
k1nty
what year is this car?? all Calibra's I have seen from K plate on have a bolt
Fraz wrote:what year is this car?? all Calibra's I have seen from K plate on have a bolt
my old h reg had a cotter pin in the door check instead of a bolt
tazz666
So did my SE and it didn't have the nylon washer either which is why i remembered it as it was different to the SE2 which has the bolt and washer.
I ended up changing the check strap as the hole where the cotter pin went through started to go square causing the door to crack. The pin was still ok
mines a k reg aug 92.they have a tapered and convaluted roll pin affair.ill check frazs number against the ones ive bought.calibras had these 89 _92 but vauxhall dont remember lol.
k1nty
Silly question mate, but are you sure its the pin thats at fault and not the hole in the strap thats squaring off
Rob i dont have clicky doors,the pins are missings and the check straps need connecting
Fraz the 195523 pt number was the ones i ordered(cav ones) they are too wide and dont fit. i wonder if nova ones are similar ?
k1nty
