after burner lights
after burner lights
by v6 steve » Thu Nov 04, 2010 9:21 pm
http://cgi.ebay.co.uk/Calibra-Rear-ligh ... 2c588e109f
not my cup of tea but im sure someone was looking for a set
Re: after burner lights
by MadOnVaux! » Fri Nov 05, 2010 6:05 pm
How do you get the boot open with them fitted?
by Callyman » Fri Nov 05, 2010 6:54 pm
With a remote button in the car.
by Fraz » Fri Nov 05, 2010 7:18 pm
or a popper operated from your alarm fob ...or a hidden switch that you also put a P9 9V battery onto incase the cars battery is flat ...or a cable hidden away someplace
by Phil69 » Fri Nov 05, 2010 11:02 pm
The lock mechanism that normally operates the central locking can be turned round 180 degrees. You shorten the operating rod and re-attach it then, as already said, it can be wired to operate from a remote button or alarm fob
