Anyone use iridium plugs?
by v6bob » Fri Jan 14, 2011 10:58 pm
Are they as good as the advertising bumf or is it wiser to stick to the ngk jobbies and save the extra cash ?
v6bob
Re: Anyone use iridium plugs?
by v6 steve » Fri Jan 14, 2011 11:05 pm
iv got them in ma turbo but i cant see the advantage of putting them in the v6
by bodgetastic » Sat Jan 15, 2011 1:52 am
Stick with cheap ones and change them at regular service interals
by Mark1 » Sat Jan 15, 2011 8:11 am
I just use standard one's in mine.
by v6bob » Sat Jan 15, 2011 9:41 am
Ill stick with the standard ones then, just thought id ask in case anyone recommended them
v6bob
by D-Man » Sat Jan 15, 2011 7:23 pm
I would use OEM as well.
by BazV6er » Sat Jan 15, 2011 10:41 pm
yep standards as well but i think this year i may have to replace the ht leads as they are 3 years old.
by Callyman » Sat Jan 15, 2011 11:20 pm
Baz my leads are 15 years old. You don't change leads unless you get a problem.
by Fraz » Sat Jan 15, 2011 11:28 pm
you used to change leads same time as the plugs, but that was the old copper core ones ...stopped them as they caused interference with all sorts of things
by BazV6er » Sat Jan 15, 2011 11:56 pm
no i think the leads will need to be changed as the car doesnt seem as good , i know ages i said to you guys that i would be changing them but back then i didnt know how to remove the rear bank ones and until you showed me that day andy ive removed the inlet manifold so many times now lol.
by Callyman » Sun Jan 16, 2011 10:19 am
Make sure you get OE leads then, anything cheap wont last and actually give more resistance.
by Mark1 » Sun Jan 16, 2011 12:45 pm
by Callyman » Sun Jan 16, 2011 1:40 pm
If you want Magnecors Baz, (and tbh they are the only ones id have except originals) they are a few quid cheaper here
http://www.europerformance.co.uk/pages/ ... =555570184
by BazV6er » Sun Jan 16, 2011 3:51 pm
no they are way out of my price range , i will stick to oe ones from autovaux tbh
by Callyman » Sun Jan 16, 2011 4:29 pm
Baz how much are the autovaux set?
