Clear headlights 2011
by Adrian » Fri Feb 25, 2011 5:58 pm
Searching around I can't find any source for the clear headlight fronts that RobbieV etc. have. The SONAR headlight module doesn't appear to be available anymore and people like Frank and 1llusion appear to have gone as well (?) Any other avenues I should be looking into?
Adrian
Re: Clear headlights 2011
by v6 steve » Fri Feb 25, 2011 10:44 pm
i got a set last year on ebay but that was just luck, iv heard of some pepole buying angle eye's just to get the clear lense from them
by lammy » Sat Feb 26, 2011 2:02 am
The angel eye units are a little more expensive thay the clear lenses (mine were £110 from 1llision a while ago and were a perfect fit!)..I believe you have to modify and grind the edge of the aftermarket unit lens slightly to make the lense fit the original units.
SE9
by Adrian » Sat Feb 26, 2011 3:07 pm
All I can find now are black units with intergral angel eyes:
Not so worried about the black as I'm only after the face - but £216 :shock:
I've got a sweet little lighting project on hold now because of this :sad-bored:
Adrian
by lammy » Sun Feb 27, 2011 8:47 pm
Are they the cheapest?... clear lenses are almost impossible to find now..I remember 1lllusion had them specially tooled and made up...good luck with your search...the units come up second hand now and again.
SE9
by Adrian » Sun Feb 27, 2011 10:57 pm
I wonder where 1lllusion has gone now? I think those black ones can be found for a bit less lammy, but not much under £200 from what I can see. Maybe someone reading this has some clear lenses to trade... :pray:
Adrian
by lammy » Mon Feb 28, 2011 1:13 am
This car is being broken on Ebay..with clear headlights (angel eye units by the looks)..may have gone by now but worth a try?
http://cgi.ebay.co.uk/vauxhall-calibra- ... 3f079022f2
SE9
by Adrian » Mon Feb 28, 2011 10:44 am
Many thanks for that! Have made an enquiry. Funny thing is I wasted several hours Sunday afternoon paging through an Ebay search for Calibra and didn't spot it - although it has to be said I didn't make much of a dent in the 17,326 results that came back :bang:
Adrian
by Adrian » Mon Feb 28, 2011 3:30 pm
^^^Gone already.
Adrian
by lammy » Mon Feb 28, 2011 6:04 pm
Gutted...keep searching....If I come across any i'll let you know.
SE9
Users browsing this forum: No registered users and 79 guests
