cam sensor
cam sensor
is a vectra b 2.5 cam sensor the same as a calibra cam sensor ???????????
thanks
thanks
Re: cam sensor
not sure as the omega has different plugs, they have rounded corners and the calibra has square corners on the plugs, the sensor will most likely be the same but check the plugs
Re: cam sensor
Depends on engine. Late Calibra V6s are the same as Vectras (also late 2.0XE). S1035179/R9003233 onwards.
Part no 90510657
Omegas are not the same.
Part no 90510657
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
Re: cam sensor
The cam sensor part number and applications came straight off the Vauxhall Trade Club site today so I assume it is OK.
