been busy today
been busy today
i had a knocking coming for the passenger side last week, turned out to be a fecked track rod end. so i picked up a set from my local dicounts guy along with a set of greenstuff pads
how is it that the fecked one popped out no bother from the leg, yet the other one which was getting replace because i was doing the other side was the one that gave me all the bother.
it was whacked with a hammer then whacked with a bigger hammer to no avail, it was heated it was lubed, eventually i had to go and buy a splitter. typical first whack with the use of the splitter and it popped
so got both changed and then fitted my new greenstuff pads. so tomorrow i might need to go out a long run and bed in the new pads
Re: been busy today
the lower arms and arb droplinks were done last year before Billing, then we done the clutch, timing belt, wheel bearings and cv joints before the Highland tour
Re: been busy today
well after a good run today it seems the track rod end wasnt the only thing that was fecked.
it sounds like the strut top bearing has gone aswell
edit- on a plus note what a difference with the greenstuff pads and the drilled and grooved discs, compared to the standard pads i used to break the discs in. the cars pulls up alot quicker now
Re: been busy today
nope thin nut on the bottom and thick one on top
Re: been busy today
I had a set of top mount bearings in the garage think some one used them tho and never replaced them
sorry iv not been about to help out but with a bit of luck I should be home soon
sorry iv not been about to help out but with a bit of luck I should be home soonsteve
Re: been busy today
that was on the 8v mate
and i did say when you needed them i would replace them
would you like me to order you a set while i'm at it?
Re: been busy today
bugger should have kept my mouth shut
Re: been busy today
well thats both strut top mounts and bearings changed and i only got soaked twice with rain, bloody weather
Re: been busy today
took the car out a test drive, thank christ no more knocking and the car feels alot better when cornering
lol
